Home > General (L494) > Auto Start Stop |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 |
As far as I know you can only turn it off on each journey but I may be wrong. I just don't press the brake as hard when i'm stopped then it doesn't do it. 16 model year yulong white autobiography
Sun Jan 31 2016 10:45pm |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 |
^^^^^^^^^ Hope that someone can find a way to over ride this nonsense.... |
Mon Feb 01 2016 3:56am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Disconnect the auxiliary battery. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Mon Feb 01 2016 8:19am |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 |
I don't know why anybody would want to? What's the issue as I seriously don't have any problem - in fact I like the fact that I'm saving fuel when stationary.
Mon Feb 01 2016 8:59am |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 |
Sorry, what button do you press ? |
Mon Feb 01 2016 9:08am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Before I had the car I thought it would drive me silly: What's the point of Stop/Start in a 550 BHP 5L supercharged V8 for Christ's sake?
Mon Feb 01 2016 9:16am |
The A OFF with a circular arrow round it in the suspension height switch pack |
Mon Feb 01 2016 9:25am |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
I am also slowly starting to use it rather then turning it off. I like the way it turn the engine off and then when you take the seat belt off, also turns off the ignition. |
Mon Feb 01 2016 5:30pm |
Easy way not to blind those following you by keeping your foot on the foot brake........... put the selector into N, engage the EPB and take your foot off the brake and the engine will stay stopped until you select D again. OK it takes a bit of practice with the timing but it works. I learned this trick with it when I had the Evoque and it works in the RRS2 too. I also thought I would reach for the off switch at every opportunity but now I never bother, as said by philmw it works really well and you do save some fuel using it............. and when I drive my defender into town I keep stalling it at the lights now I'm so used to the Stop/Start! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Feb 01 2016 5:56pm |
This annoys the living daylights out of me. Often, when I stop, I need to make a note of mileage on my biz miles sheet. That liver on the back seat, and to get to it I have to undo the seat belt - and then the bl**dy car turns itself off before I have made a note of the mileage. Then I have to turn it back on and wait for the boot up sequence to finally end. It truly is the single most annoying feature for me. If I want to turn the car off, all I have to do is press a button, I don't want, need, or desire the software to decide to do it for me. Same thing if I want to undo the seat belt to turn completely around to see where I am reversing. Bl**dy annoying. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
Mon Feb 01 2016 7:49pm |
Why don't you just use the InControl app for all your journey and mileage data? |
Mon Feb 01 2016 8:04pm |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 |
Personally the auto stop/start drives me nuts principally because occasionally when I put the car into reverse, the engine stops and does not restart. I then have to put the car in Park and restart the engine on the button. The trouble is that this is intermittent and I have not been able to demonstrate the problem to my dealer. I have taken to switching the auto stop/start off before I put the gearbox into reverse. I know that auto stop/start is now fitted to most new cars but as far as I'm concerned it's not an answer to any question I asked |
Mon Feb 01 2016 8:33pm |
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 |
Yes it can be disabled. I have read on US Forum how this can be done. They say you simply have to disconnect the positive terminal on the small battery behind the right hand rear panel. Have I done it No as the auto start stop does not a annoy me and besides I have a finger that can push buttons if required. |
Tue Feb 02 2016 5:03am |
Because I will simply forget if I don't do it at the end of a journey, that is my routine and dammed if I see why some stupid software should make me change it. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
Tue Feb 02 2016 6:10am |
