Home > For Sale & Wanted > [Wanted] Heated Steering Wheel with Paddle Shift |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
If you don't have the heated wheel as standard then you will need the clock Spring I'm afraid.
Fri Jan 29 2016 5:52pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Strange this one according to L/R Microcat vehicles after Vin No. AA000001 had the later Clockspring Pt. No. LR018556 fitted which they obviously haven't. I guess the only way to be sure is to remove airbag and check first.
Fri Jan 29 2016 6:15pm |
