![]() | Home > Tips & Tricks > intercooler query |
benj193 Member Since: 22 Oct 2015 Location: United Kingdom Posts: 53 ![]() ![]() ![]() |
hi guys,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Correct |
flindersstation Member Since: 02 Jan 2019 Location: Scottish Highlands Posts: 17 ![]() ![]() ![]() |
What were the symptoms of the split intercooler pipe? I'm getting a noise under hard acceleration and I suspect it might be a split pipe. |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
The people in the car behind you will be cursing as you pull away. |
Black smoke, lack of power, and sometimes an ESF warning on the dash ![]() |
Thanks, it turns out my issue was that the cooling fan was warping at higher revs and the touching the casing... so solution was to slightly trim the cooling fan. 2007 RRS 2.7 HSE (Current)
