![]() | Home > General (L494) > Reduced performance in colder temperatures? |
eddkawasaki Member Since: 23 Feb 2015 Location: Lancashire Posts: 93 ![]() ![]() |
I noticed this too, at first i put it down to the fact i was wearing big insulated boots! I then came to the conclusion that it was something to do with the "Auto" on the terrain response which may be changing the throttle response to dull the power in potentially icy conditions. i also found that when i put the gearbox into sport mode with terrain response in auto it automatically changed to "command shift" whereas if i selected "dynamic" in the TR then sport mode on the gearbox it stayed in auto shifting. |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 ![]() ![]() |
Ah, very good point, I didn't think of that. I'll try disengaging the Auto on the terrain response to see whether that makes a difference. Predictably of course, the weather is about to warm up so maybe I won't get a chance to test this theory. Certainly this morning with the temperature 3 or 4 degC milder, the car felt livelier from the off |
I had a play while i was out today. mine felt a bit sluggish although it was not too cold but the snowflake was on. so i stuck it in general program and it was fine again. stuck it an GG & S and it was sluggish and if you stick it in sport then it drops into command shift too. so I'm thinking it was definitely this.
Me too. I've just taken my car out and the difference with the Auto button off and on is significant. As you say, its a shame there isn't a message on the dashboard confirming that the Auto TR has modified the driving program
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 ![]() ![]() |
So, just to be clear, do we think that at less than 3degC the Auto Terrain Response changes the program to "snow and ice" without any intervention? Regards
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Absolutely.
In the days on manually selected TR programmes selecting the Grass Gravel and Snow setting had an amazing dampening effect on the throttle pedal and almost made you think that there was something wrong with the system as the take off was terrible and any acceleration very slow. If you have eperienced driving on compacted snow then you will realise just how good the system is as you will only be allowed the amount of power that the ABS/Traction Control sensors calculate that the car can handle in the conditions and as grip changes the pwoer allowed changes. I ended up on one journey very slowly working up to 60mph on the snow bound M74 and was not in the least surprised to have FFRR's and Disco3's also fitted with TR overtaking me, I thought 60 was pushing it but those guys had way more confidence in their cars/ driving skills than I had in mine!
True but, as I've experienced myself, that acting automatically is potentially dangerous if the performance is modified without the driver expecting it. There should be a message on the dashboard drawing the driver's attention to the change in mode. I can imagine L-R ending up in a US court over this if a driver could prove that the performance of his L-R was modified without him knowing, resulting in an accident. Car manufacturers have ended up in US courts for less than that. Btw is there anything in the manual about this behaviour? Also isn't the system a bit crude if it only reacts to temperature? Surely it should be reacting to wheel slippage as well as temperature? |
Yes, I also thought it changed modes by measuring wheel slip in snow etc. Using temperature as a criterion is strange as you can easily have perfectly dry but cold conditions.
The indicator you seek is the "snowflake" turning red from amber. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Big brother is controlling you.
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
I think the car goes into Grass Gravel Snow at about +2 degrees. If you press the TR button to take it out of auto it shows you the mode it was in before whilst in auto mode. And this is often the case. Not reduced performance as such, just the car adjusting |
I don't understand - what is stopping you taking it out of auto TR and doing whatever you please with it? So you can do exactly as you might like. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
Nothing except I was told by my dealer to keep it in Auto all the time. If the salesman who handed over my car at the time had pointed out that at low temps, the TR automatically reverted to GGS based on temp only and that reduced performance would result, I might have known to take it out of Auto |
