Home > Technical > Timed climate - again!! |
bajer Member Since: 25 Feb 2017 Location: london Posts: 3 |
Hi, have the new AGM battery solved the issue? I'm having the exact same problem now. |
Sat Feb 25 2017 2:41pm |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Probably the same issue as on the D4.
Sat Feb 25 2017 4:46pm |
Johnski Member Since: 02 Sep 2015 Location: North Wales & North Yorkshire Posts: 1407 |
Not the same issue, but reading about temperature FBH works (up to 5c). I've noticed my FBH has come on the last two mornings, when the outside temperature is 10c yesterday and today 11c. Anyone reading know why it's coming on above 5c and should I worry, besides burning a bit extra fuel? Thanks. John
Sat Feb 25 2017 10:19pm |
When new battery fitted the BMS system will need a reset anyway Now driving a rather smart looking Van |
Sun Feb 26 2017 1:39pm |
So it was reset (JRL SDD) BMS after replacing the battery,
Mon Mar 06 2017 10:04am |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 |
did the test again after CTEK charging for 1 hour and the timed function starts no problem.
Mon Jan 27 2020 1:09pm |
new battery in and the timed climate works perfectly by the timer...
Tue Feb 11 2020 3:43pm |
