![]() | Home > Orders (L494) > Dynamic or not? |
I don't know if it is still an option but you could go for an HSE with the on road/ off road pack, that doesn't give you the Dynamic mode or the ediff IIRC so is a bit less expensive, however I think that if you enjoy the odd blast on twisty roads then going for an HSE Dynamic would make for a more enjoyable, less rolly drive as Dynamic does make a noticable difference to the handling and firmness of the ride and makes it a much more sporty car. If you only want 4WD for the muddy bits then the plain HSE with OnRoad/Offroad would be fine but IIRC you don't get the low box on HSE without that option. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
I was in a similar quandary as there is a fair price difference between the HSE and HSE Dynamic.
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 ![]() ![]() |
It's the dynamic mode that makes it the car it is . The first time I drove one in sport dynamic mode for a late night blast down to Cornwall was the day I decided to place my order. |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
Well put Fletcher, personally I find dynamic gets far more use than I thought it would - |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
What Fletcher said - it was a back lane blast in Dynamic + Sport that made me realise how these cars can handle, and convinced me to put my money down.
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
Mine is an HSE - not driven a dynamic so not sure what I'm missing but mine handles pretty wellnfor what I use the car for |
Stuff Member Since: 29 Jan 2016 Location: In between cradle and grave Posts: 11 ![]() |
I would not be without the Dynamic. It is truly, truly impressive. Also go for the TFT instrument panel. And go for the TDV8 if you can afford it. |
TTF Member Since: 22 Nov 2014 Location: Wiltshire Posts: 75 ![]() ![]() |
Dynamic definitely adds the sharpness that the chassis and ali body deserves.
Polar Bear Member Since: 05 Oct 2015 Location: solihull Posts: 8 ![]() |
Just bought Swmbo a my16 hse
In the same way the sport setting on the gear box is not standard - to use Landrover terminology switch on dynamic for "Spirited" driving... |
