Home > Faults & Fixes > rrs 2005 limp mode showing p0191 fuel pressure sensor
thq786
hi, bought a range rover sport 2005 last week and it wont go over 2000 rpm, got it checked out and they told me its some fuel pressure sensor p0191 was the code can anyone tell me what part number it is as i cant find any on internet thanks.
mods-can you move it to proper section if its in wrong one thanks
Post #484739 Thu Jan 14 2016 1:29pm
Paddi
Can you fill in your profile so we know what engine you have?
Was it a private sale? If bought from a dealer then they have to fix it at their cost.
That code is just a generic code. You need to have the fault codes read with a land rover specific tool and it will have two more digits to specify exactly what the fault is.
With just the generic code all you know is there might be a problem with the fuel pressure or it could just be the sensor.
Find yourself a good local Land Rover independent specialist with the correct diagnostic tool and start from there. 2008 MY Java Black TDV8 HSE
Post #484752 Thu Jan 14 2016 4:50pm
thq786
Ok thanks
Its tdv6 2.7 engine
Post #484762 Thu Jan 14 2016 6:49pm
Disco_Mikey
Low fuel pressure can be caused by restricted fuel flow, or a weak pump
Start with an OEM fuel filter. Cheapest and easiest place to start Thumbs Up
Post #484777 Thu Jan 14 2016 10:35pm
thq786
Thanks ill try that tomorrow
Post #484781 Thu Jan 14 2016 11:01pm
thq786
update: ok so got it fixed, it was a dodgy performence box off ebay, unplugged it and working fine now.
notice 3 more faults
1- parking sensors are not working always beeping in reverse
2- cigarette sockets are not working, cant find fuse box to check fuse.
3- cruise control not working or maybe i dont know how to turn it on? help
thanks
Post #484912 Sat Jan 16 2016 3:06pm
Aaron92
Sorry to reply to such an old thread but this turned out to be very helpful my Range Rover wouldn’t go over 20mph and had every fault code under the son stored , turned out to be a cheap tuning box that a previous owner must have fitted , removed and it’s perfect again.
Post #570994 Thu Dec 13 2018 1:40pm
