Home > Wheels & Tyres > Wheels and balancing issues |
If it comes and goes like that I'd suspect a binding front brake caliper. My old WJ Jeep did that once - really quite alarming shaking that started suddenly and it was a binding brake. The fix is new or rebuilt calipers.
Sat Jan 09 2016 5:01pm |
RRSNUT Member Since: 23 Jun 2013 Location: Deep in a South Wales Valley Posts: 37 |
I currently have the same issue and have found rear offside wheel was extremely hot, did not dare touch the disc the heat coming off it was enough to let me know there is an issue
Sun Jan 10 2016 1:46am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Hi Rrsnut had same issue on my old D3 problem wasn't the Calipars but the handbrake shoes which had sieved, new shoes and correctly adjusted job done. 2008 G4 RRSport TDV8 current
Sun Jan 10 2016 8:40am |
Dirksdonuts Member Since: 18 Jun 2015 Location: Oxfordshire Posts: 12 |
Thank you guys for you views and advice i will get it booked in for those things to be checked and update you |
Tue Jan 12 2016 7:54am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
One thing that has come up a few times on here was water inside the tyre. Don't know how it got in there (water in garage air pressure tyre inflator?) but can give similar issues of intermittent wheel imbalance.
Wed Jan 27 2016 4:52pm |
