Home > Technical > Suspension fault 06 rrs
Jonesyscoob
Got a fault started a few weeks back, compressor runs for about 10 seconds when car started, then cuts out and Amber suspension light comes on,
Got fault codes
C1a13 pressure not decreasing when venting gallery
Uo416
Uo132
Suspension won't go up or down and is now down low so very bumpy
Also got the Amber p light on next to the parking light if this is connected?
Can't see any broken/damaged wiring
Have started to remove compressor today to have a better look but can't get two rear pipes off
Any help or advice welcome
Post #483491 Tue Dec 29 2015 4:34pm
dcf54321
Very similar to mine, pipes fittings corroded brass aluminium and steel !!! compressor replaced with the latest (LR061663 - Vardy Aberdeen)had to cut the pipes but you need to shorten the pipes for the new the compressor Razz
Post #484279 Fri Jan 08 2016 11:04am
