Home > General (L494) > OBD Saver
rigiver
Scotland
OBD Saver
Has anyone fitted one of these to a MY 15 RR Sport, and if so how easy is it to access the OBD port.
http://sailesmarketing.com/shop/obdsaver/o...landrover/
Also has anyone had a security recall to modify the port, I heard there was a mod which prevented any more than two keys being associated with any one vehicle.
Thanks
Ian
Post #482576 Wed Dec 16 2015 3:02pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Looks like a neat little device, but there are much cheaper ways of disabling your OBD port Wink
Post #482578 Wed Dec 16 2015 3:06pm
wilf
Spill the beans then? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #482582 Wed Dec 16 2015 3:37pm
Slim444
It's covered elsewhere on the forum i think, but involves cutting the data line to your OBD port and putting a small switch in a hidden place. Pins 7 & 15 spring to mind Wink You can also put a switch on pin 16 (battery +ve) but a clever scrote will more than likely have a device with it's own supply!
Plenty of OBD pinouts diagrams around the web too...
Of course, on a 15 plate, you may not want to be cutting wires under the dash Cool
Post #482586 Wed Dec 16 2015 3:52pm
Lost for Words
If you block access to the ODB port they need only find another bit of CANBUS to use instead...
Besides, there are now software updates to prevent key programming now anyway. Thumbs Up Visiting from DISCO3.CO.UK
Post #482591 Wed Dec 16 2015 4:09pm
Autobiography
Not needed after the KVM security upgrade. The OBD is not very useful to them.
Post #482612 Wed Dec 16 2015 6:36pm
