Home > In Car Electronics > Car resetting |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Take it to a land rover specialist independent who know these motors like the back of their hand.....they are complex motors that need guys with experience Visitor from fullfatrr.com
Thu Nov 12 2015 7:04pm |
Mitchell Hill Member Since: 12 Nov 2015 Location: Birmingham Posts: 3 |
Couldn't agree more! Just wondered if anyone else had had the same problem |
Thu Nov 12 2015 7:20pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I had a similar issue and it was one of the battery connections not on tight enough. Sounds like you've checked test though. |
Thu Nov 12 2015 7:50pm |
Ill double check them. I'm at a point where I'll try anything |
Thu Nov 12 2015 8:22pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
As above sounds like a bad battery connection. Make sure you check both ends of the battery leads though..also check starter connections and any earthed you can find.. 2008 G4 RRSport TDV8 current
Thu Nov 12 2015 10:27pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Be sure to check the alternator voltage while you're there too. Visiting from DISCO3.CO.UK
Fri Nov 13 2015 9:21am |
