Home > Technical > Starting problem
supercharged01
England 2005 Range Rover Sport Supercharged Santorini Black
Starting problem
Hi, on start up my supercharger starts then cuts out, does it about 3 times past 3 mornings. when it starts on 4th go it still doesn't rev up like it should and doesn't drop down when I put it in gear. I put a higher amp battery on it yesterday and no change this morning. Any ideas please?
This post has been edited by the site administration team
Please keep the question to one thread in one section
Post #476548 Fri Oct 16 2015 7:58am
tanloverluke
i'm guessing a fuel issue, fuel pump/pressure related. I had this issue a little while back and that was the cause. there may well be other causes though. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #476556 Fri Oct 16 2015 9:14am
supercharged01
Thank you, I have it booked in the garage tomorrow so hopefully they can find the problem. I did think fuel related as it feels like its starving itself. Will keep it posted.
Post #476557 Fri Oct 16 2015 9:30am
