Home > General > RANGE ROVER SPORT DOOR LOCKS
DOOR LOCKS
YES
50%
 50%  [2]
LOCKS
50%
 50%  [2]
Total Votes: 4
Patrick16
United Kingdom 2007 Range Rover Sport TDV8 HST Bonatti Grey
hi everyone has any one had a problem like this i have a 2007 range rover sport 3.6 diesel
DOOR LOCKS WILL NOT LOCK ON ALL FOUR DOORS FROM REMOTE OR SWITCH IN CAR NO FAULT SHOWING ON DASH LOCKS BOOT AND TAILGATE BUT ALL FOR DORS DONT LOCK
can lock manually inside then the remote does lock door then opens fine but will not lock all four doors any ideas Embarassed Big Cry
Post #476535 Fri Oct 16 2015 6:43am
SRE
Spain
Do a search on here and the Disco Forum, door locks failing is a common issue. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #476553 Fri Oct 16 2015 9:43am
My TDV8 had the driver's lock replaced a couple of months ago. It's a known D3/RRS fault. 2012 SDV6 - it's missing a couple of cylinders
Post #476554 Fri Oct 16 2015 9:46am
Mark41
driver's door lock failed a couple of months ago on our 2006 TDV8. Had it replaced under the warranty be bought with the car. Now seems there is problem with the passenger door lock as it won't lock untilthe remote is pressed 2 or 3 times
Post #476754 Sat Oct 17 2015 11:56am
Patrick16
its all four doors on mine and switch inside ???
Post #476764 Sat Oct 17 2015 1:03pm
mr_spaceuk
I had to replace the drivers door lock, rear near side lock and both boot catches and both boot buttons.
The boot was a real pain as it locked the Mrs out of the boot and couldn't get the kids stuff in, at a busy car park.
Good as gold now they have been replaced.
Post #477919 Mon Oct 26 2015 9:57pm
Patrick16
Hi yes tried all locks with spare one it works few days then stops working then just starts working again someone has said there is a sensor in the roof lining that senses if the car is occupied ???
Post #477944 Tue Oct 27 2015 7:25am
