Home > Technical > Rrs inlet manifold urgent help required
Harry1
Can anyone tell me if you have to take body off to fit drivers side inlet manifold on 2010 sport and how long it should take its a v6
Post #474049 Wed Sep 23 2015 7:22pm
Disco_Mikey
You don't on the 2.7, so I don't see any reason why you would on the 3.0
It is a bit of a faff about mind...
Post #474061 Wed Sep 23 2015 8:09pm
Olly-ibiza
Im currently changing both rocker cover/ inlets on my TDV8 the passenger side one is split blowing inside of the rocker box.
iv just stripped it right down to the point of pulling the injectors out, which is why I logged on to see if anyone has done this before and if it needed a puller or anything to get them out?
BTW I didn't have to take the body off spiteful Range Rover Sport tdv8
Post #474143 Thu Sep 24 2015 4:01pm
Olly-ibiza
Post #474144 Thu Sep 24 2015 4:03pm
Olly-ibiza
Just pulled them all out no bother spiteful Range Rover Sport tdv8
Post #474146 Thu Sep 24 2015 4:36pm
steve cowdell
England 2010 Range Rover Sport 3.0 TDV6 SE Stornoway Grey
has anyone got a step by step for doing the l/hs rocker cover on a 3.0 tdv6? cracked in the usual place Sad
main stealers want 1.5k to do it for me.
Post #492783 Tue Apr 05 2016 1:11pm
