Home > General (L494) > Cracked tailgate
scriv
United Kingdom 2013 Range Rover Sport Supercharged Siberian Silver
Cracked tailgate
Has anyone else had this issue.Car goes in to have tailgate adjusted as it has dropped slightly on one side but have now been informed that the tailgate has cracked and needs to be replaced.
Post #474016 Wed Sep 23 2015 4:27pm
Tim in Scotland
Not on my RRS but I managed to crack the tailgate of my Evoque on a very cold morning................ total cost was £1600.... Big Cry after Labour and VAT, I should have done it as an insurance claim............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #474023 Wed Sep 23 2015 4:51pm
scriv
They are telling me it's a warranty claim just awaiting approval
Post #474029 Wed Sep 23 2015 5:25pm
scriv
Well went and collect car but on handover noticed that all the rear badges where missing while this was being looked into notice bent rear wipe and the Censored roof has been damaged left their fuming and back in a ds Big Cry Big Cry Big Cry
Post #475070 Fri Oct 02 2015 4:26pm
Farmer Chalk
Thread resurrection.....
Anyone else had this....? My 17 plate RRS with less than 20,000 miles has just been diagnosed with a cracked tailgate... since purchase last year it has had an annoying squeak from the rear. Dealership has been excellent and identified that the tailgate has cracked. LR Warranty refused claim but dealers have spoken to JLR who have agreed to replace...
Will keep you posted....
Post #612456 Sat Apr 10 2021 7:24am
jd2uk
I'm getting a squeak from the rear of my 2018RRS when it goes over any sort of bump. The dealer has acknowledged the issue and it is booked in to be investigated shortly. After reading this I've had a look and it appears the tailgate it a little loose when closed and that the noise could be coming from the gas struts. Should there be this sort of movement in the tailgate when it's closed? Where did you tailgate crack and was this evident without removing all of the trim? I don't just want the gas struts changed (or worse just lubricated) if there is a more fundamental issue as my warranty will be up soon (although I am planning to take out the LR extended warranty).
Post #613642 Fri May 14 2021 10:26am
Farmer Chalk
Sorry for the late responseā€¦
It cracks across the mountings in the top corners of the tailgate where the hinges areā€¦. You can take off the outer covers and just see itā€¦.
Mine replaced by JLR after the Approved Used Warranty refused to pay outā€¦
Didnā€™t cure my rattle though which appears to be the inside of the plastic slam panel cover covering the boot latch.
Post #615614 Sat Jul 10 2021 11:30am
