![]() | Home > In Car Electronics > 4x4 information screen |
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
Hi all, my 4x4 information screen is not working. It doesn't change at all when I alter the suspension settings. The levels do not change and the wheels do not move. Also sometimes when I start the car, the Land Rover logo stays on and I cannot access any of the screens functions. I've also noticed that the screen isn't very bright, so I've altered the settings and it brightened up for a bit, but seems to Go back to the lower brightness level after a bit and the settings need to be altered again. It's driving me up the wall..... Anybody got any ideas what's going on..... 2008 Supercharged Stornaway Grey, 22inch black Stormers
Try a hard reset, disconnect the battery cables and touch them together for 20 seconds, then re attach to the battery. |
Needs to be in off road mode for the compass to show. |
I've tried the hard reset, also had the battery checked and the charging system. All are good. I've recently had a new compressor fitted, and a dodgy height sensor replaced. It used to work ok. Can't put my finger on when it stopped working properly though. 2008 Supercharged Stornaway Grey, 22inch black Stormers
Just to add some further information, I can force the screen on by using the secret button at the top of the screen and instead of putting the code in, i just press ok. The Sat nav, Tv and 4x4 info screens then come on........ But the 4x4 screen does not alter when I change the suspension settings, or turn the wheels..........
