Home > Faults & Fixes > What suspension compressor do I buy?
bjohnny@hotmail.co.uk
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Sumatra Black
I have a 2006 Range Rover sport 4.4 HSE. I’ve been told by my local Mechanic I need a new air compressor (sounds like its working fine but doesn’t raise the car) I have been told I need different types/makes of compressor by different people. I’m hoping there is a RRS expert on here that can give me a definite answer on what compressor to buy. I have attached a picture of my current compressor, I’m guessing it’s not original as it says AMK 2012 on the sticker.
Also is there anything else I should check before buying a compressor, as mentioned it sounds like its running fine, however the car is not raising at all, its on the bump stops and is very bouncy, error message is "Susspenssion Fault"
I look forward to any advise, thank you.
Johnny
http://www.rrsport.co.uk/gallery/albums/us...ressor.JPG
Post #473495 Fri Sep 18 2015 11:45am
Disco_Mikey
Check for air leaks Thumbs Up
It's quite uncommon for the AMKs to fail...
Post #473496 Fri Sep 18 2015 12:09pm
Ive had a little look around the compressor for leaks, didnt see anything. Will have a better look tonight. Hard to get under the thing with it being dropped so low. Cheers mikey Thumbs Up
Post #473499 Fri Sep 18 2015 12:24pm
I have had another look at the compressor, I cant feel any leaks but I did notice a pipe above the compressor that isnt connected to anything (see pic attached) do you think this is a pipe thats come off or could it just be an overflow pipe for something?
Post #473528 Fri Sep 18 2015 4:40pm
