Home > General > SAT NAV |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 |
Has anyone found that when you put your "HOME" details into the satnav, that it doesnt quite correspond to the exact location as to where it shows your car position ....... my home appears approx 2cm away ?
Fri Sep 23 2005 9:58am |
unfortunately 2cms on the satnav
Fri Sep 23 2005 11:09am |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 |
Mine is right slap bang on, if i park on the drive i am park on the house if you understand what i mean. Its out there somewhere. Second V10 Treg on the drive at the moment. |
Fri Sep 23 2005 11:18am |
rhodyrover Member Since: 27 Jul 2005 Location: Rhode Island Posts: 27 |
Yes occasionally i am right on top of my house and sometimes off to the side. I guess it also depends on the positioning of the satelites. 2006 RRS HSE, Chawton White, Alpaca with Cherry Wood Trim (Luxury Interior Pkg)
Fri Sep 23 2005 11:44am |
tasmod Member Since: 07 Aug 2005 Location: NE Lincs Posts: 396 |
Fri Sep 23 2005 12:04pm |
I dare'nt try this when the car is full of family will end costing me a packet. They are always hungry Its out there somewhere. Second V10 Treg on the drive at the moment. |
Fri Sep 23 2005 12:09pm |
Spent lunchtime playing around with satnav, didnt realise you could go into calibration ... thus enabling you to reposition " HOME " having checked that the calibration for the satnav positioning itself is/was spot on.
Fri Sep 23 2005 1:23pm |
rainor Member Since: 30 Oct 2005 Location: Baltimore, MD Posts: 2 |
You should re-calibrate your GPS - that should fix the problem.
Mon Oct 31 2005 2:00am |
caporajm Member Since: 25 Jul 2005 Location: Austin, MN Posts: 55 |
not to make light of the fact that the GPS is off, but if you're using the GPS to go home then you should know where your own home is without having to rely on your GPS Food for thought
Mon Oct 31 2005 6:26am |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2581 |
I don't think mine is exactly positioned on my house but by the time I have reached within a few miles of home it doesn't really matter that much. L319 D4 HSE
Mon Oct 31 2005 7:25am |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 |
I set my home position when we first got the car. Then after about two months, the home position changed by itself and moved our house into the middle of a field about 300yds away. Maybe the car is itching to do some off-roading
Mon Oct 31 2005 10:01am |
modena Member Since: 21 Oct 2005 Location: montreal Posts: 5 |
i still dont have a copy of my NaV cd...
Tue Nov 01 2005 11:19am |
Technically I'm sure a copy would work, but legally of course is a different matter. It's not fair on Martin to be promoting illegal activity on one of his forums.
Tue Nov 01 2005 11:25am |
Your dealer should be able to get direct from the manufacturer without delay. ( or you and charge him for doing so ) see link to Navteq http://www.navteq.com/ProductFinder?Langua...=mapupdate or read details in other topic/thread :- http://www.rrsport.co.uk/forum/viewtopic.php?t=445 Hope this helps modena " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
Tue Nov 01 2005 11:36am |
