Home > In Car Electronics > Reverse camera where is it?
caperbility
United Kingdom 2005 Range Rover Sport Supercharged HSE Java Black
I've just bought a 2007 RRS HST Supercharged that has a rear view camera fitted which looks like a standard fitting rather than a aftermarket one if you get my drift.
Trouble is there's no sign of it being there on the main sat nav screen ie nothing happens when you put the car into reverse
It also has a TV tuner fitted which works surprisingly well so my question to you knowledgeable people is how do I go about getting it working?
Come on Ian where are you help me out mate Very Happy
Thanks in anticipation
Post #472508 Wed Sep 09 2015 6:16am
Lost for Words
I'm afraid there was no camera fitted from the factory. The only way to get the screen to change automatically, is using a GVIF interface (or putting the screen in FFRR mode, but that messes stuff up...).
A GVIF is usually set to trigger automatically, so, most likely, the camera is wired into the screen input, and can be accessed manually from the hidden menu (http://www.disco3.co.uk/wiki/Hidden_Menu).
Thumbs Up Visiting from DISCO3.CO.UK
Post #472529 Wed Sep 09 2015 8:34am
Bodsy
Site Sponsor
The 07 is the same as your last RRS I'm afraid, so would need the gvif installing again. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #472594 Wed Sep 09 2015 4:50pm
caperbility
Cheers for that chaps
Are you up this neck of the woods anytime in the not so distant future Ian?
Post #472606 Wed Sep 09 2015 6:13pm
