![]() | Home > Wheels & Tyres > Hunter Wheel Alignment |
KennyR Member Since: 28 Jul 2015 Location: Gourock Posts: 178 ![]() ![]() |
Any recommendations for Hunter wheel alignment in the Glasgow area? ____________________
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Look on their website http://www.alignmycar.co.uk/ |
Cheers 1JBS, place 10 miles from home! |
wastower Member Since: 12 Sep 2013 Location: Dunoon Posts: 21 ![]() ![]() ![]() |
Hi
Thanks, not had it done yet but that's where I'll be going, good to get a recommendation! ____________________ Current: MY2023 3.0 SDV6 Autobiography in Eiger Grey Gone: MY2019 3.0 SDV6 Autobiography in Carpathian Grey Gone: MY2015 4.4 SDV8 Autobiography in Corris Grey with ebony and lunar leather Gone: MY2013 3.0 SDV6 HSE Black Edition in Orkney Grey, piano trim, black leather with contrast stitch |
They are very knowledgable about all things RRS associated, they remapped mine, wow, what a difference |
I'm still under warranty, think a remap would void it! ____________________
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
I can recommend Pro grip, based in Larbet. Used him for my previous RRS and did a good job. He even put the RRS in low tolerance mode and gave me print outs of before and after. Must get my FFRR done soon as well.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Had an alignment done this afternoon, with the Hunter equipment.
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
So what are we talking as a ball park figure? I realise that the more the alignment is out, the more it is likely to cost, especially if there are worn parts that need replacing; but lets say it only needs a few adjustments...... |
My alignment yesterday was £49.99 to adjust the front camber and toe, and £24.99 to adjust the rear toe, but would have cost more to adjust the camber |
Thats not bad actually. Far cheaper than having to fork out for new boots prematurely. |
Had this done at Autotec in Port Glasgow today, bit confused, they said no adjustment was needed and didn't charge me but the print out has the front camber in red but I shouldn't worry about it? Also the print out has the car as Range Rover L405, I drive a 2013 RRS1... have they checked against the wrong settings?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Would of thought anything in the red is wrong and requires adjusting, I would be inclined to take it somewhere else that know what they are doing, may even get the Model correct.
Weird thing is Col, they have a good name locally and there was 4 Range Rovers in their bays, so they have a rep for RR... also said wishbones would need to be replaced to adjust front camber. ____________________
