![]() | Home > General (L494) > Brakes Squealing - Am going to burn the car.... |
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 ![]() ![]() |
Hi Iain
Have you driven down any long gravel drives or resurfaced roads that have been given an all weather granite chipping surface recently? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
iainm Member Since: 20 Mar 2015 Location: Cardiff Posts: 48 ![]() ![]() |
Thanks Guys for the responses
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
I think the hesitancy, which has existed since the D3 came out, is a gearbox issue rather than an engine/turbo issue. My guess is that it's about making the pull away "cultured" rather than "boy racer". That or it's protecting the gearbox in some way. 2012 SDV6 - it's missing a couple of cylinders
Not sure its do do with being cultured, rather than "boy racer"; more, you see a gap at a roundabout, want to go - car hesitates, moves off in second, then changes into first; cue lurching forward and off down the road.
I thought that using the Sand setting (with it's launch control) and paddleshifts got around this problem and does the same problem exist with the 5.0l S/C's or is it specific to just the SDv6? I've never found it to be a problem so either I'm driving like a granny or not all RRS's suffer from it 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
You don't need sand mode, just manually select 1st gear with the stick (or paddles). 2012 SDV6 - it's missing a couple of cylinders
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 ![]() ![]() ![]() |
Nope the S/C doesn't (not that I have mine at the moment). Currently in a loaner SDV6 and the lag is there but nowhere near as bad as it was on my XF...!! 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography ![]() |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
I thought the SDV6 loaner I had last week was much better in terms of "lag" than my current XF, I really have to drive around that. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Update:- vehicle is back from the dealer
Yes, it will be good news for the dealers as they don't need to give discounts on new cars and give terrible part-exchange values on the car you would like to sell back to them................. great news for the dealers/ salesmen, bad news for the owners 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
brakes still squealing like a little piggy..........FFS!!! |
Interesting,
DVMK Member Since: 26 Sep 2015 Location: UK Posts: 4 ![]() |
My brakes also squealing from 15mph to 0. (15k miles on the clock). Dealer (in London) checked it and said nothing wrong and nothing could be done. But then again not the best dealer as my car has had to go in so many times - at least once in 3 months and an average of 2-3 attempts to fix each problem - I also seem to have all the standard set of faults like fuel tank slosh, lag on acceleration from zero, wiper smear, humming sound from 22' wheels and latest a smelly AC on startup. I am so fed up. I like the design and look of the car - but after sales service is just a complete joke and wish there were better laws to protect consumers during warranty. |
