Home > Technical > Slow acceleration |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
EGR valves. Sounds like they have both failed. Blank them, and report back |
Sun Aug 23 2015 7:09pm |
Rucka01 Member Since: 23 Aug 2015 Location: Newcastle upon tyne Posts: 4 |
Going in garage Thursday to go on computer fella reckons it's th egr valves stuck open. Do you think these can just be cleaned/freed? Many thanks |
Tue Aug 25 2015 10:19am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
No, it's normally that the bearings fail, so cleaning yields nothing. On a EU3 car (05/06MY), they can be blanked without any software modifications, so this is cheap, easy and better for the engine and fuel economy. Visiting from DISCO3.CO.UK
Tue Aug 25 2015 10:24am |
Hi been on computer at garage today both valves have faults on them he cleared them but came back on again. I told him to blank them but he just said I should go to a range rover dealer for repairs as he isn't comfortable working onit. I'm on holiday about 100miles away, do you think it will be ok to drive home to go to my local garage I trust? As I say it drives fine once up to speed just a bit smoke off turbo? Many thanks |
Thu Aug 27 2015 5:03pm |
Depends really, only you know how bad it is? The lag can get quite dangerous pulling out of juctions, so be sure to keep it in mind.
Fri Aug 28 2015 7:21am |
Garage blanked off both valves and the car is driving better than it ever has! Thanks for your advice much appreciated |
Thu Sep 03 2015 8:28am |
