Home > Faults & Fixes > Front power socket/cigarette lighter socket not working |
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 |
Hi all, the front power socket/cigarette lighter socket isn't working, to be honest it hasn't been for some time and just thought I had better get it fixed. I have checked the fuse and it is fine, any other ideas as to what it might be ? many thanks. 2017 Range Rover Sport HSE |
Fri Aug 21 2015 6:01pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5033 |
Is it possible the centre consuls has been removed at some time and the socket connector not re-connected when consul refitted.
Sat Aug 22 2015 8:18am |
Its no big deal but would like to try and get it back working, will investigate further, ta for reply. 2017 Range Rover Sport HSE |
Sat Aug 22 2015 12:40pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
Did you find this problem, mine is doing this.
Fri Dec 04 2015 12:18pm |
redamo Member Since: 13 Oct 2015 Location: Cheshire Posts: 72 |
Same here, but I think it's corrosion. Light is on. Coincidentally the cubby fridge isn't working either. Checked all fuses, nothing wrong. Need to investigate further.
Sat Dec 05 2015 7:54pm |
CDS Member Since: 21 Sep 2011 Location: Oldham Posts: 25 |
I'd check the fuse, no55 behind the glove box, 15amp Over for a visit from disco3.co.uk |
Thu Dec 10 2015 11:22pm |
When I originally checked I went off the fuse layout in the handbook which was F15 - School Boy Error! When I followed the diagram on the back of the glove box (as pointed out by CDS - Clive) the fuse F55 had blown. Replaced it (with a fuse kindly donated by Clive) and all is now good. 2016 Black SDV8 Autobiography
Fri Dec 11 2015 9:30am |
Fresh pair pair of eyes is sometimes all thats needed Over for a visit from disco3.co.uk |
Fri Dec 11 2015 9:48am |
