![]() | Home > Maintenance & Modifications > Leaving car for 6 weeks - any setting to conserve battery? |
ExpatPom Member Since: 30 Jan 2011 Location: Melbourne Posts: 90 ![]() ![]() ![]() |
Hi All,
crammy Member Since: 21 Aug 2014 Location: essex Posts: 167 ![]() ![]() ![]() |
can you get one of the solar chargers that plug into cigarette lighter if you have a constant live |
Disco Member Since: 15 Nov 2013 Location: Telford Posts: 178 ![]() ![]() |
Lock it in access mode will help. |
basil Member Since: 28 Sep 2014 Location: East Midlands Posts: 26 ![]() ![]() ![]() |
Can you explain why access mode uses less power when the car is locked? |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 ![]() ![]() |
Certainly for the L320 put it Locked Access Height as it stops the car waking up to check its level.
There's no need to lock it in access height, just lower it. The theory is not that it stops it self leveling but that it sends all the electrics to sleep so that they don't continuously look for your key fob. I used to leave my 2005 and 2007 MY RRS's for up to 4 months without battery problems when connected to a £10 Maplin solar panel as a trickle charger. It is very important that you buy a solar charger with a blocking diode so that come night time the solar panel doesn't cause the battery to discharge the main battery. Unfortunately, in their wisdom LR since 2011 have made the power sockets and cigarette lighter disable when the ignition is off. They did kindly reinstate the one on my 1st Evoque when the battery wasn't lasting 3 weeks when not on trickle charge but once they had sorted out the problem with rapid discharging batteries they also re-inhibited the cigarette lighter! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks for the advice everyone. The car will be in an underground car park, so the access height idea might be the one for me to try. MY15.5 Fuji White, SDV8 HSE Dyn Stealth Pack
I am not familiar with the L494 but are you able to open a door with a key as you can with the front passenger door on the L320? If so then you should be able to leave the car but might have to call the RACV or LR assist if the battery is flat.
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 ![]() ![]() ![]() |
I left mine for 4.5 weeks and it was "critically low" on my return, however I didn't lock it in access height so I think it might be "touch and go" but reckon you'll be ok! 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 ![]() ![]() |
I've left mine in the garage for the next 2 months, just left it unlocked
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
how about unplugging the battery?
Pleased to report that the car started first time when it was bought to pick us up from the airport this weekend having done nothing special at all other than lock it and leave it.... Friend parked it up for us after taking us to the airport and I didn't want to confuse him with the access mode idea! No dramas luckily. MY15.5 Fuji White, SDV8 HSE Dyn Stealth Pack
