Home > Technical > Loud clunk noise after lca's fitted.
Shohaib
Hi just got new lca's fitted on rrs 55 plate.After 1 days of driving the vehicle i was parking in a car park fully locked the steering wheel and heard loud clunking noise never had this before only makes loud clunk noise when fully locked left or right ,this has only happened after got the new lca's fitted can anyone help
Post #470261 Thu Aug 13 2015 12:49pm
Disco_Mikey
Big blob of grease on the lock stops on the wishbones, and hub carriers Thumbs Up
2 on each side, on at the front and one at the rear of the arm
Post #470266 Thu Aug 13 2015 1:09pm
SRE
Spain
I assume you had the arms fitted by a Land Rover Garage ???
If not, then were they fitted correctly, not sure exactly, but I am pretty sure you must have the arm jacked up to the correct level before tightening the mounting bolts.
Also check the calliper mounting. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #470268 Thu Aug 13 2015 1:18pm
kozzone
Finland 2007 Range Rover Sport TDV6 HSE Stornoway Grey
I got both of my front lca replaced two weeks ago. Took two days of driving when my both upper ball joints started to make loud clunk noise. I replaced both upper arms with ball joints just to make sure everything is tight now.
Post #470274 Thu Aug 13 2015 2:59pm
