![]() | Home > Technical > Engine system failure |
Any smoke when driving, loss of power just before it fails?
Budgenio Member Since: 12 Aug 2015 Location: London Posts: 2 ![]() ![]() ![]() |
No smoke , get 'engine system fault ' on dash then no power in acceleration , just coasts to a standstill. Switch off , start up again and seems to be ok.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
Seized turbo actuator or split hose |
hasbeen Member Since: 07 Aug 2015 Location: Loire Posts: 1 ![]() ![]() ![]() |
Hello. I have a TDV8 here in France. We do all the maintenance here in our own workshop, as can't afford the mortgage that would be needed to pay for French servicing. All that is, except taking it back to the UK last year for a body off and new turbos .............. but when the body was off, they found it was both exhaust manifolds having warped that was causing the problem! Fitted the new turbos anyway, as the body was off. Have had split top intercooler hoses before (2), and all in all are well accustomed to engine system fault codes and re-booting from limp mode. |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Budgenio
ceos Member Since: 29 Jan 2017 Location: Sydney Posts: 3 ![]() ![]() ![]() |
I have the same problem with my tdv8. Did you find the problem with your tdv8? I am off to the dealer tomorrow but mine goes into limp mode every few kilometers so any advice would be appreciated. Regards Chris |
