Home > General > Very low access height!!
garrycol
Australia
They are so simple - the hardest part is putting in the switch either on the console or steering column housing.
The black box itself plugs into the Suspension ECU which is under the drivers dash within easy reach. You just unplug the suspension ECU plug and plug in the LLAMS ECU into the Suspension ECU then reconnect the suspension ecu loom to the LLAMS ECU - the LLAMS ECU in my car is held in place by velcro dots to the suspension ECU.
The hard bit is finding a spot and installing the switch.
After it is all in you just calibrate it and all is done.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #469918 Sun Aug 09 2015 11:40am
Buckster
Thanks for the info garrycol Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #469974 Sun Aug 09 2015 8:17pm
