Home > Tips & Tricks > Constant power to 12V sockets-SOLVED!!
Davebc
Canada 2007 Range Rover Sport 4.4 V8 HSE Stornoway Grey
Have a US spec RRS HSE MY07 and I just tried the fix by removing the relay and bridging the top and bottom connections as shown in the sticky in this section with same title. Happy to say I have constant power to centre outlet but not in the luggage compartment~is this a model quirk or do I need to bridge the other two connections to get both outlets live?
Also of note, its a Censored getting the wire in that small opening, if you wear a watch you might wanna take it off!
Thanks for any help/advice on this.
David 2007 Stornaway Grey RRS HSE 4.4 V8
Post #469648 Thu Aug 06 2015 4:38am
Davebc
Happy to say that I have solved the problem of no constant power to the rear compartment 12V outlet.
Seems that when I added a tow hitch and wiring I neglected to reconnect the connector to the 12V outlet 😱 It's all good now lol. 2007 Stornaway Grey RRS HSE 4.4 V8
Post #531122 Mon Jul 24 2017 6:08pm
donny dog
I hope you're careful about how much use you make of it (battery-wise).
Post #531134 Mon Jul 24 2017 7:55pm
Davebc
Originally wanted constant power to 12V outlets in order to run a solar power battery tender, which works fine btw. I had followed the directions as posted by Very Annoyed and Tiny but only got power to the center outlet-thought there was something out with my vehicle, turned out something was out with my reassembly lol.
Thanks for the reply. 2007 Stornaway Grey RRS HSE 4.4 V8
Post #531136 Mon Jul 24 2017 8:03pm
