![]() | Home > General (L494) > Locking your keys inside a RRS with comfort access |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Yup - doable....
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
There are (I think) 7 key sensors around the car including in the boot to stop this from happening, but do know of it happening to an Evoque so is possible. Probably a combination of location and other stuff forming a black spot.
The not closing and beeping when the key is inside is what normally happens. If, however, the key is in a dead-spot or blocked by other things around it then the boot will shut with the key inside. For the Evoque case I menioned, the car was locked and then the boot opened, the key was in a bag that was put in the now open boot and then the boot closed, and locked. |
Change the wife? |
robbo770 Member Since: 13 Nov 2013 Location: Aberdeen Posts: 248 ![]() ![]() ![]() |
![]() ![]() ![]() ![]() Gone rejected RRS autobi Dynamic MY14.5 (Peter Vardy 👎) D3 XXV full conversion 4.2 SC FFRR 4.4 FFRR Freelander 1 |
forest172 Member Since: 03 Apr 2013 Location: Derbyshire Posts: 104 ![]() ![]() |
Happened to us yesterday. Wife opened boot with comfort access and with key in her handbag. She put handbag in the boot with key inside and shut the boot.
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
Whenever our car detects a key inside it won't allow you to lock the car. However it does appear to have a black spot near the back of the boot as the car won't start if the key in my wife's bag at the back. Different car I know, but just my experience.
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
Comfort access is the BMW keyless system like this. It will not let you put your key in the boot and close it. I know I have tried.
If you place the key in the boot and try to shut the boot with the car locked, it does a double beep and re-opens the boot.
