Home > Detailing & Car Cleaning > Car Polisher Advice Sought |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
I have heard that DA (Dual Action) are the best.
Fri May 29 2015 8:57am |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 |
DA's are the "safest". You've pretty much got to work at ruining the paint with one of those to be able to do damage, where-as a rotary can burn through quite easily if you're not experienced. DA's are also good for applying the likes of glazes etc, or difficult to get to areas.
Fri May 29 2015 9:10am |
Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104 |
Agree 100% with ian.h for a starter defiantly go with a DA even some professionals still use a dual action over a rotary in most situations down to its ability to be so safe on the paint. I my self own a buff daddy pro da which i have used on my rrs to get what I would in my view consider an amazing job. That said this is a deep rabbit hole and not something for the faint hearted. Took myself and a helping hand a little over 9 hours to prep ( wash, clay, iron x, wash, dry) then using the da and choice of polish (meguairs 205) wipe down (ipa 10%) then 2 coats of wax ( collinite 476s). Choice of products are down to personnel preference most established brands get about the same results. |
Fri May 29 2015 1:04pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 946 |
great advice from the previous posts, i tend to favour Meguiars products and have a G220 DA polisher and a variety of pads, also a variety of Meguiars polishes and compounds. keep trying to find the time to do the RRS but in all honesty its not too bad. Did have the chance to use it on my wifes car after i reversed it into a ticket machine , the rear quarter panel was a mess, you could have grated cheese on it,,,,, a bit TLC with the polisher and varying compounds and it was brand new, was quite proud of myself ! ,,,, wifey was still not impressed though. I heard someone say once that the only way you can damage paint with a Meguiars polisher is to throw it at the car !
Fri May 29 2015 4:56pm |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 133 |
This is a bit drawn out, and there are 5 parts to it, but there is a whole load of good advice
Fri May 29 2015 6:04pm |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
Biggest and most important but of advice here ☝🏻 |
Fri May 29 2015 6:24pm |
[quote="sterling01"]This is a bit drawn out, and there are 5 parts to it, but there is a whole load of good advice
Sat May 30 2015 6:21am |
Mark41 Member Since: 30 Apr 2015 Location: Preston Posts: 18 |
thanks everyone for all your input. Think am going to look at a DA now. Can I use normal Meguiars Ultimate Polish with a DA or do I need a special polish?
Sun May 31 2015 12:08am |
the meguiars ultimate range of polishes, waxes and compounds can be used with a DA, thing to remember is that all polishes are abrasive using the correct grade of pad is important, i use the cutting, polishing and finishing pads, depending on how much correction is required. You would'nt think to look at them there was any difference,,,,,,, the diference comes when they are in use. 2010 RRS, TDV8
Sun May 31 2015 3:42pm |
