![]() | Home > Technical > Rain sensing/auto wipers |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Obviously I don't have the car yet or the manuals but I had rain sensor in the BMW, and the way they worked was that if the wiper stalk was in the intermittent position when you insert the ignition key the wipers will be set to auto, whereas if you return the wiper stalk to position 0 before starting up and then subsequently put the wipers onto intermittent, the auto feature was disabled.
d3matt Member Since: 12 Jul 2005 Location: Oxfordshire, UK Posts: 730 ![]() ![]() ![]() |
On the Sport, when you put the wipers into intermittant, then they are in auto mode. You do therefore not have an intermittant feature if you have auto wipers. Matt
Simon Member Since: 13 Jun 2005 Posts: 44 ![]() ![]() |
The adjuster on the stalk is for the rear wiper intermittent interval, not for the sensitivity adjustment of the rainsensing front wipers......according to the manual. |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
This morning I used my wipers for the 1st time ( i only picked the car up on friday ) as I needed to clear the front screen so pulled the stalk for a quick single wipe..... only to find it did this plus the rear wiper also gave a single wipe? I only wanted to wipe the front screen & not the back as that was clear(ish) and didnt want to wipe dirt over the rear screen |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 ![]() ![]() ![]() |
flick the switch downhill and you get a single wipe of the front wipers. i agree the auto wipers are a bit useless but will just have to put up with it.. |
Simon, not according to the manual I'm reading. See http://www.ox11.net/downloads/rrs-wipers.pdf for the wipers section of the user manual. Matt ------------------------------------------- RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance! |
The wiper stalk isn't designed very well. On most cars, if you pull it forward it cleans the front screen - but on the Sport it cleans the back - very annoying - I always get it wrong. See http://www.ox11.net/downloads/rrs-wipers.pdf for full details. Matt ------------------------------------------- RRS ownership for 1 yr, then D3 for 2 yrs. Then cut back to old bangers and working my way back up through two Peugeots in 6 months. Now got Saab 9-5 2.3t and enjoying the performance! |
Cheers guys, its just getting used to the different actions" the stalk " utillises............old habits die hard |
Can't argue with that......but I think my explanation is what actually happens. Otherwise the inference from the manual is that the rotary bit has two functions, which seems unlikely. |
caporajm Member Since: 25 Jul 2005 Location: Austin, MN Posts: 55 ![]() ![]() ![]() |
So to add on to this.. what about the headlight washers.. how do you turn them on? RRS S/C Special Edition, Vesuvius |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
The headlamp washer only becomes active when the headlights are switched on and work every fifth wash of the windscreen/windshield. Its out there somewhere. Second V10 Treg on the drive at the moment. |
This is what I did today... a tap down on the stalk ( as per instructions in manual ) to just wipe front screen, but it also activated the rear wiper as well. Is this because the rain sensor dictates everything ( if so very annoying ) May have to visit dealer to clarify. Yours totally confused by the damn things ![]() MDP ![]() " WITH MORE EXTRAS THAN A HOLLYWOOD EPIC " |
aaahhh...Life's rich tapestry !
Simon, you're right. I drove it in the rain tonight and after playing with the adjuster, I accidenlty found that it was in fact adjusting the delay of the rear wipe - from 4 seconds to 13 seconds. Yet, my manual says it adjusts the sensitivity of the rain sensor on the front. Well, I'm happy now that I know it is actually doing something! Matt
