![]() | Home > Technical > Over-eager PDC! |
Hi all,
Yeah, whilst my car was beeping all around me over the weekend I was wishing for an iDrive screen with that on |
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 ![]() ![]() ![]() |
I have the same problem. Mine beeps whenever it feels like. I can be stopped at a light when no one else is there and it goes off. |
Sorry to Hi jack:
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2584 ![]() ![]() ![]() |
Yup E39 M5. Not sure what the transition will be like yet as I don't have my RRS S/C yet! But, when I sold the M5 last month I certainly missed it, I've been driving around in small hire cars (Meganne and Clio) since, so the RRS should feel like a huge awesome beast. However I come from a family of 4x4 owners and have had them in the past so it won't be shock with the different driving dynamics. Zipperman No, not a member of e60.net, the main forum I used was BM3W.com L319 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB |
Biggles Member Since: 26 May 2005 Location: Preston, Posts: 916 ![]() ![]() |
I notice that when rain water runs of the bonnet when coming to rest at road junctions it can cause the pdc to activate. But also it is very sensitive and does warn earlier than any other car I have had with the system fitted.
It's a Land Rover, you didn't expect it to work properly did you?!!! |
Thanks for the feedback guys. So it looks like it's just one of those things... will try and remember to turn the PDC back on again when I head for a multi-storey car park! |
scorpio Member Since: 08 Jul 2005 Location: London Posts: 142 ![]() ![]() ![]() |
have found the front pdc to be a complete nuisance, and with the good vision from the front I think unneccesary. Were going of at all unusual times and places and started far too early.\\\The rear pdc, is great |
Geordiehillbilly Member Since: 22 Aug 2005 Location: Newcastle Posts: 32 ![]() ![]() ![]() |
Strangely I've noted that the beep occurs mostly when I'm pulling up to red traffic lights. Not sure if they are emitting anything that the car is maybe picking up. Even stranger than this, I notice when I pull up or past a bus, the PDC often goes off..... |
Toodeep Member Since: 09 Jul 2005 Posts: 42 ![]() ![]() |
PDC seems to switch itself on below a certain speed and yes it does seem to have too great a range around 45 degrees to the front so that it responds to passing motorcycles and oncoming vehicles in an adjacent lane. If I remember the BMW (X5) system only activated once reverse had been selected (as is usually the case when entering or leaving a parking space) and stayed active until a given speed when it was reasonable to assume the manoeuvre was over. Unlike the RRS system it was otherwise off by default with a button to switch it on if required. Seemed simple enough to me! Range Rover Sport TdV6HSE in Bonatti Grey + 20" Stormer wheels (ex X5 and ML driver) |
Esoteric Member Since: 01 Oct 2005 Location: Northern VA Posts: 21 ![]() |
My only gripe is tha tyou can not disable one PDC only both at the same time. I see no need for front PDC but rear is very useful. |
