Home > Technical > RED SUSPENSION FAULT LIGHT ON DASH |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
I presume those are the only codes?
Tue Mar 17 2015 10:29am |
CMLE Member Since: 03 Jan 2014 Location: Shropshire Posts: 48 |
Thank you 'Lost for Words'.
Tue Mar 17 2015 11:20am |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 |
.....dicky ride height sensor maybe? I was born with a photographic memory. Shame it didn't develop!
Fri Mar 20 2015 9:45pm |
Thank you Gaz!!
Fri Mar 20 2015 10:59pm |
I don't know if it works on later cars but on pre 2010MY cars if you switch the info screen to the 4x4 screen where you can see the suspension and steering and diff lock if fitted, then on the flat if you have a red bar above any of the suspension limit indicators on the screen that used to show which sensor was faulty 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sat Mar 21 2015 1:08am |
