Home > Technical > rear fuel pump location ... ?
mswesty
Wales 2005 Range Rover Sport TDV6 HSE Java Black
hi all
first post , bought my RRS just over a month ago and have to say i love it!
BUT , "engine system fault" / limp mode, came up a few days ago , on route for a diagnostic check it stopped and wouldn't start .
i had it recovered and they found code p1260 low fuel pressure system issue.
I'm going to change the pump in tank myself , my question is can i access from above under rear seat area or does the tank have to come out?
best regards
mike
Post #454798 Thu Mar 05 2015 10:11pm
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
The tank has to be dropped to gain access but the code can come up for a few reasons. You can do a few more checks before condemning the pump:
http://disco4.com/forum/topic125793.html
Thumbs Up Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #454802 Thu Mar 05 2015 10:36pm
mswesty
thanks ,
i always appreciate it when the original poster returns to explain the out come so here goes.... )))
code P1260 low fuel pressure system fault .
engine turns with no start / ignition suspected fuel loss.
theres a pipe drivers rear engine with a shrader tyre valve fitted, turning the engine while pressing the centre pin down shows no fuel from rear / tank .
tank down, 6 bolts with no vehicle parts obstructing the removal.
the pipework above the tank is the tricky bit as its clipped to the tank with sponge soundproofing trapping it to the body of the tank , note where they go .
the access hole from above is tight, the pump is clamped with a green unit to the bottom of the inside of the tank . it comes out as a whole assembly with pipes and wires everywhere .
12v directly to the pump on the work bench shows its failed .
a tap with a hammer starts the pump up again !
two minutes later the pump required another tap to get it going ..
eurocar parts unit was completely different so i bought one from bear march nearby.
reassemble was straight forward .
turning engine with the schrader valve depressed until fuel comes through a second later the car started . problem solved
it took us four hours lying on our backs with trolley jacks etc.
my local landcover specialist wanted 4.5 hours to do the work((
Post #455368 Mon Mar 09 2015 10:38pm
Gornal Hills
Hi all, after reading this post im left wondering could this be the whiring culprit on my sport ?? seems to be toward the rear, less noticeable on acceleration but more prominent going down hill or coasting, less fuel requirement ?? please help Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #455371 Mon Mar 09 2015 10:54pm
Rowdie
fuel pump noise ?
Hi Guys
Can someone tell me if a very quiet wirring noise from the rear of my 2015 L494 when stationary, is likely to be the fuel pump. No error codes or any performance issues, but just want to know if I should worry and how big a job it is for a dealer to do under extended warrantee.. Also do they just get noisier or just eventually fail. It is only audible when stationary, and only sometimes at that
Any help and advise gratefully received
Post #604552 Mon Sep 14 2020 5:09pm
