Home > Maintenance & Modifications > Got my DRL's done!!
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Got my DRL's done!!
Well if I can do it....anyone can!
I'm so chuffed with the result. The photo's don't really do them justice as they are super bright and crisp white.
Can I just thank everyone who has contributed to the DRL threads. Thumbs Up Bow down
 I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #454037 Fri Feb 27 2015 7:16pm
Calder
England 2006 Range Rover Sport TDV6 HSE Rimini Red
Leds
Hi any pics of how you fitted them ,they look good ......
Post #454042 Fri Feb 27 2015 8:02pm
jmcvs
Scotland 2006 Range Rover Sport Supercharged Buckingham Blue
They look well good, well done Thumbs Up , makes me want to do mine now. 2006 4.2 Supercharged Buckingham blue
2003 BMW X5 4.6is Estoril blue
2006 Yamaha FZ6
Post #454044 Fri Feb 27 2015 8:24pm
B9BS X
Looking great mate Thumbs Up
ere did u buy the kit from and how long did they take to fit? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #454045 Fri Feb 27 2015 8:29pm
ABSport
That looks cool Gaz, well done.
Post #454046 Fri Feb 27 2015 8:36pm
tanloverluke
very smart...and matching side lights !!!! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #454048 Fri Feb 27 2015 8:39pm
Gaz
Yeah....got the Dabhees ones. I liked the look of the 5 led rings.
Did the whole job in a day. Probably 2 hours per light. Maybe and hour for the engine wire up.
I wanted to take my time so I didn't make any mistakes.
Used a heat gun, not an oven.
Got everything laid out first.
Removed lights from car. Remove the retaining clips.
Unbolt the light brackets. One has four bolts.
The other has three bolts.
Two bolts are visible. You need to pull the sliding clip right up to make the third bolt visible.
Worked the heat gun on it's low setting around the light to soften the resin.
I took my time here. Used a flat head screwdriver too.
Move a little....reheat...move a bit more...reheat until it comes away.
Drilled a hole to take wires and countersunk the hole because of the resin around where the cables are attached to the ring.
It needed to sit flush.
I keyed up around the light rim with some sand paper and set the rings on with some resin glue and spray activator.
Didn't take any photos but drilled the rear of the light, passed the cables out the back and silicon sealed.
Refitted the lens with more heat. Refitting the retaining clips helps keep it in place.
I also sealed the perimeter of the lens with clear silicon for good measure.
Refit the mounting brackets.
Hey presto!
(Sorry the photos are sideways!)
Gaz I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #454050 Fri Feb 27 2015 9:04pm
tanloverluke
very clean job there Gaz! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #454051 Fri Feb 27 2015 9:08pm
Gaz
Thanks mate....you were a top help too! Thumbs Up Bow down
Gaz. I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #454052 Fri Feb 27 2015 9:13pm
Nsp1
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
That's a thumbs up from me.
Do they stay on when you put the lights on?
Post #454053 Fri Feb 27 2015 9:13pm
Gaz
Yeah. Got them wired for max brightness.
They are on with engine running and stay on with side lights and main lights.
Now that they work as DRL's....I'll leave my lights on Auto. Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #454055 Fri Feb 27 2015 9:44pm
stevew
United Kingdom 2009 Range Rover Sport Supercharged Zermatt Silver
Awesome Thumbs Up
Post #454056 Fri Feb 27 2015 9:45pm
B9BS X
Great job mate Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #454058 Fri Feb 27 2015 9:47pm
