Home > Detailing & Car Cleaning > settings for autobrite lance
crammy
United Kingdom 2007 Range Rover Sport Supercharged Stornoway Grey
hi all
I received my magifoam and lance yesterday so looking forward to the weekend Thumbs Up
There is no instructions so just wondered what type of setting you guys use to get the thickest foam that doesn't just run off. I wasnt sure what the dials do. i assume the top one is pressure and the other open and closed some metal flaps.
thanks
jay
Post #453644 Tue Feb 24 2015 10:09am
steve2026
2005 Range Rover Sport Supercharged Vesuvius Orange
Not sure about that particular lance, but the best way is to experiment, it depends on water hardness as well, the softer the water the better the foam.
It might well take you a couple of washes to get it right, but make sure you jet wash the car first before applying the foam. 2005 Vesuvius 1st edition ( now sadly gone ).
Post #453663 Tue Feb 24 2015 12:31pm
put an inch of magifoam in the bottom, top up with hot water to about 5 inches
the front nozzle will fan out the foam, tight the metal flaps are and the top dial will make it foamier
a little trial and error depending on pressure washers output pressure and water hardness
Post #453665 Tue Feb 24 2015 12:38pm
crammy
thanks guys
ill just have a play then.
I have noticed some people put foam on dry and some jet wash first like you say. I would of thought putting on dry would be best as the foam is more likely to stick. ill do some digging into this
jay
Post #453672 Tue Feb 24 2015 2:11pm
Chrisr1806
I stay on a dry car. Arrived: MY16 A/B SDV6 in Aruba, Ivory interior, piano black trim, black panoramic roof, spare wheel, blind spot monitoring, mudlaps and more... Twisted Evil
Gone but not forgotten:
2014 RRS2 SDV6 HSE in Loire Blue
2011 Freelander 2 SD4 HSE in Santorini Black
Post #453674 Tue Feb 24 2015 2:41pm
steve2026
The general idea of foaming etc is to get as much dirt and grime off before you touch the bodywork with any mit or sponge, thus reducing the risk of damaging the finish of the paintwork.
So the more you can budge using the jet wash and foam the better, hence why most will jet wash first, but of course it's up to the individual. 2005 Vesuvius 1st edition ( now sadly gone ).
Post #453677 Tue Feb 24 2015 2:56pm
Garage Door Medic
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Make sure EVERY TIME you use it, fill the bottle back up and flush the foam out of the lance. If you don't after a couple of months it will block up and it's a bit tricky to take apart, to clean it properly. Had mine a year now and still works like new and use it 3 times a week MY 13 3.0 SDV6 HSE Black Edition
Santorini Black
Ivory Premium Leather
Side steps
Disklok !!!!!!!
Mud Flaps
Spare wheel protector
Post #453722 Tue Feb 24 2015 8:37pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Jet washing also scratches the car by applying preasure on the dirty areas. Theres so many arguments for or against rinsing before foaming but altimately do what you think. Some people like the look of foam sticking on the car, personally I rinse lightly then foam and this is what I think works best. In my opinion. I'm not Fat. RRS TDV6 HST.
Post #453725 Tue Feb 24 2015 8:45pm
crammy
Ill give both methods a try.
Thanks for the heads up on cleaning
Post #453728 Tue Feb 24 2015 9:04pm
zaphod
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
If you are going to jetwash first then make sure you have a nice wide spray pattern set and have it hitting the car at a 45 degree angle. This way the pressure is reduced (spread over a wider area) and also any grit that is dislodged should be deflected off the car rather than being pounded into the paintwork.
Post #453752 Wed Feb 25 2015 9:29am
Ian.H
My usual order of things (for the body):
  • Foam
  • Rinse
  • Foam
  • Rinse
  • Wash with ONR (one panel at a time)
  • Dry washed panel with microfibre towel.. normally sprayed when wet with Sonax Xtreme Brilliant Shine detailer
  • Finishkare 1000P wax
  • Spray again with Sonax XBSD to get rid of any wax "gassing"
  • Obligatory 'stand back and admire' Cool
Wheels normally consist of:
  • Either bilberry wheel cleaner or Chemical Guys Premium Blue Wheel & Rim Cleaner
  • Agitate with brush
  • Rinse
  • Wash with ONR
  • Dry
  • Seal with Poorboys Wheel Sealant
  • Dress tyres with GTechnic T1
Used to allow ~4 hours for a "quick wash" of my Focus RS... although a quick wash of the RRSport the other day amounted to about 2.5 hours, and that didn't include waxing or doing the wheels properly (it was cold, and I was limited with available time unfortunately).
Tardis & Iron-X used in the process too every few months.. likewise, claybarring maybe 3 times a year before machine polishing / correcting.
Cheers..
Ian
Post #453788 Wed Feb 25 2015 4:07pm
crammy
cheers zaphod, ill bare that in mind
time to go shopping i guess then ian. looking forward to the warmer weather when its enjoyable to do the car in the garden with a few chilled bevergages Laughing
Post #453795 Wed Feb 25 2015 4:48pm
zaphod
Amen to that - cleaning the car at this time of year isn't that much fun if I'm totally honest Laughing
Post #453796 Wed Feb 25 2015 4:57pm
Ian.H
Totally mate! My paintwork is in appalling condition right now as I've only had it 3 months and the weather's been pants.. can't wait for spring either to get out there with the polisher and sort it all out.
Just a word of warning with ONR if you went that route... do NOT use it with a lambswool mitt.. use either s synthetic mitt or a proper sponge (yes, I said sponge!.. something like a zymol sponge for example). I did this and half way through washing the RS, my mitt fell apart catastrophically!
Was brand new.. half a car later:
Cheers..
Ian
Post #453798 Wed Feb 25 2015 5:12pm
crammy
Bloody hell. Looks agresive stuff.i had never heard of onr until I googled it after reading your post.
Post #453842 Wed Feb 25 2015 11:16pm
