![]() | Home > Technical > Torque Convertor noise ?? |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Noise when releasing gas pedal. Could this not just be something like boost preasure being released from the turbo? Like pressure coming out of a waste gate or something? Not sure if they have them but perhaps try it in neutral see if you get the same noise.
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
You could try a 'stall' test. Check tranny fluid level first.
rooby_roo Member Since: 17 Feb 2015 Location: Hereford Posts: 5 ![]() ![]() ![]() |
Thanks ill try the test in the morning |
i couldnt find anyone to check the oil level for me so i did the test anyway, it will rev up to 2000 rpm but no more, i revved it for about 3 or 4 seconds, or if the oil is low would this test prove inconclusive ?? |
If it stalled and there were no noises I'd reckon the torque convertors fine. |
No it didnt stall m8, i only revved it for a couple of seconds on 2000 rpm, would it have stalled by then ? |
"Stall" doesn't mean it killed the engine merely that the revs were held at a constant speed by the torque convertor at the engine's revs for producing max torque and thus max load on the drive-line while the throttle is wide open.
ok ill give it another go, does it have to be up to temp ? or can i jump in it now and give it a go ? ill hold it on the revs for 5 secs |
Baz0195 Member Since: 29 Jun 2018 Location: Telford Posts: 23 ![]() ![]() ![]() |
Hi there, I have the same symptoms but at 2000 to 3000 revs. I’ve just tested mine & it stalled & got no noises etc, any ideas please |
