Home > Technical > Winter Front Grill
WolfgangK
Germany 2012 Range Rover Sport SDV6 HSE Nara Bronze
Winter Front Grill
Hello, there is a winter front grill available from LR. If you drive in cold areas.
It was free of charge. You have to change to the orignial one obove +15 ° C .
There is a service bulletin for it . Q245
Regards
WolfgangK
 2012 RRS SDV6, Pan European ST 1300
gone : Audi A6 Allroad, Toyota LC HJ 61,
Honda CB 750 Four
Post #452204 Wed Feb 11 2015 12:06pm
muddywheels
Milk Float Man
Good posting Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #452211 Wed Feb 11 2015 12:42pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Why is it sealed? Does the cold air do bad things in there?
Post #452388 Thu Feb 12 2015 9:54pm
The diesel engines need the FBH running quite a lot in cold weather. This suggests that the engine might struggle to get to, and stay at, operating temperature in very cold conditions. This grill will reduce the cold airflow through the radiator and so help the engine stay warm.
It sort of harks back to the old radiator blankets of the Series days... Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #452390 Thu Feb 12 2015 10:14pm
designboy
So I have a hawke grille on mine and I'm now wondering should I pop on a blanked one over winter as this one has lots of air allowance. It sort of makes me think this is the reason to why my steering fluid went overheated and black on the cold snow days we had. Since then I replaced the fluid and it's been grand. But we had snow again and the same issue. Would that be the case? I'm happy just topping up at the minute if it happens again. But Fi gers crossed.
If it was the cold weather that would make a bit of sense to it.
Post #453460 Sun Feb 22 2015 11:33pm
t72bogie
United Kingdom 2008 Range Rover Sport Supercharged HST Java Black
Is this only for real winters....like not in the UK ? its not like its often minus zero during the day time even in winter cheers
bogie
2008 RRS 4.2 Supercharged HST
Post #453889 Thu Feb 26 2015 12:30pm
designboy
Lol - real winters Wink
Okay, point taken. Bow down
Post #453970 Thu Feb 26 2015 8:41pm
t72bogie
one would think the "most capable car in the world" can cope with a British winter without modification Smile
....surely these things are for like arctic circle trips and such like ? cheers
bogie
Post #453972 Thu Feb 26 2015 8:53pm
