Home > General (L494) > Constant 12v in the trunk
bergkjo
Sweden
I am trying to find a cable with constant 12 v back in the trunk for my home made sms controlled fbh remote. I cannot figure out how to dismount the interior under the power outlet. Does anybody know where all the clips are? (I have a RRS 2014)
I have also found cables right beside the spare wheel, going to the towing hitch. (See picture)I have checked a few of them with my multimeter, couldn't find any constant 12 v.
Suggestions?
/John
The manual showed me how to....just pull back the cover and there it is, the fusebox and battery! Purchase a separate fuse for the gms relay and plug it in an empty slot.
Post #450663 Sun Feb 01 2015 9:54am
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
This helped me a while ago to get constant feed to rear cigar lighter. May help.
Constant power to 12v sockets Report post
On 2007 tdv6 centre and rear power sockets are on a seperate relay and fuse to the front cigar lighter outlet. Rear and centre outlets can be set up to be non switched from ignition by removing relay r203 from behind glove box and putting a wire bridge across the power terminals.
Image of bridge to get constant power, just a wire with a suitably sized spade connector on each end.
Its got a sticky on post in Tips and tricks Thumbs Up Thumbs Up
Supporting the London Air Ambulance with my Brothers
Post #450672 Sun Feb 01 2015 10:36am
flydive
http://www.rrsport.co.uk/forum/topic12783.html '08 RRS TDV8
Post #450675 Sun Feb 01 2015 10:51am
panda
Wish I could put link up Sad bit to technical for me. Laughing Laughing
Post #450682 Sun Feb 01 2015 11:05am
bergkjo
Sweden
Thanks, I have a RRS 2014 and I don't think that the wiring is identical.
Shouldn't there be a cable with constant 12V in the towing hitch connector?
Post #450683 Sun Feb 01 2015 11:08am
panda
Crying or Very sad Crying or Very sad SORRY Crying or Very sad Crying or Very sad
Post #450684 Sun Feb 01 2015 11:11am
