Home > In Car Electronics > Ligth problem
Nilsen990
Norway 2006 Range Rover Sport TDV6 HSE Java Black
Ligth problem
Hey. Can any one tell me where the fuse to light in the power window switch and the light to the gear,park brake switch. Its a 2006 rr sport hse. Thanks
Post #449010 Mon Jan 19 2015 6:04pm
Nilsen990
Post #449101 Tue Jan 20 2015 1:07pm
There are two fuse boxes on the RRS. The first one i would check is in the lower glove box compartment. Open it, then you will see two runners one either side to support the glove box once opened, force those runners in towards the glove box and lower the glove box further. You will then see the fuse box behind it. Thumbs Up
The second fuse box is under the bonnet to the right hand side near the bulkhead if looking at your vehicle as you open your bonnet.
Welcome to the site. Thumbs Up
Post #449108 Tue Jan 20 2015 2:37pm
I'd be surprised if the lights have a separate fuse to that of the control they are lighting. 2012 SDV6 - it's missing a couple of cylinders
Post #449182 Tue Jan 20 2015 9:50pm
