Home > In Car Electronics > Help please....Will this fit my car ??
marcoos_1
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
Hi,
I have placed a wanted add on the forum for an instrument cluster for my 09TDV8, but I spotted this on ebay (hope the link works)...
http://www.ebay.co.uk/itm/Range-Rover-Spor...3cf0a91779
Can anyone tell me of this will work on my car? It looks the same.....but that's about as much as I know!!!
Thanks in advance for any help you can offer.
Post #448846 Sun Jan 18 2015 3:44pm
Bodsy
Site Sponsor
Looks ok although can't confirm if it's 2007 onwards (which is what you need) They indicate it's 2008.
you need to copy the car configuration file from your existing instrument pack onto this replacement on for it to work properly.
Use a faultmate msv2 or similar for this task. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #448866 Sun Jan 18 2015 5:43pm
Hi
That's showing a 8000rpm Rev Counter, pretty sure you will find that fits a petrol variant i.e Supercharger. My 09 plate TDV8 shows 6000rpm.
Post #448874 Sun Jan 18 2015 6:42pm
marcoos_1
Thanks guys......that's one thing I didn't notice.....the different revs.
I guess it'll need to be an actual TDV8 one then .........(as I'm guessing the TDV6 rev counters are different also?)
Post #448907 Sun Jan 18 2015 10:02pm
