Home > Faults & Fixes > Door Leather Bubbling |
DaveB Member Since: 11 Aug 2014 Posts: 38 |
It's a shame no one knows an easy fix for this but I can see it's a problem even though it seems to be the wrong way around. It's almost as if the leather expands when it gets cold and then contracts and stretches back to the normal shape when warmer. Hard to imagine I would have the only RRS with this problem but as it's blatantly obvious when it happens I'll have to assume no one else here has
Tue Jan 06 2015 11:26am |
I did read about a similar issue where the top of the door card had turned sticky, sorry but not sure where or what forum I read it on. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Tue Jan 06 2015 2:30pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I have this exact same trim and I frequently leave my car for a week without touching it (and in the past for 3 or 4 weeks without touching it, oops) and I have not seen the issue you describe....
Tue Jan 06 2015 6:34pm |
It's only bubbling up when the interior gets really cold, less than around 3 degrees. I was away in Germany over Christmas in a different car and so the RRS was left standing on the drive and the temperature was below zero when we got home. It was the following morning I noticed this phenomenon for the first time.
Tue Jan 06 2015 9:52pm |
