![]() | Home > Faults & Fixes > no power from pull off |
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 ![]() ![]() ![]() |
Could be something, like a loose hose, whilst waiting for your mechanic to return, id advise you to check all the hoses & connections. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Split turbo hose or a failed EGR valve. Both fairly common, and cheap enough to rectify |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 ![]() ![]() ![]() |
It's not been set to grass/gravel/snow on the Terrain Response controller has it? That can make it feel very slow to pull away (for obvious reasons). 2012 SDV6 - it's missing a couple of cylinders
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Sounds like faulty EGR valve, get them blanked off...blanking plates less than a tenner.... |
kevtonge Member Since: 23 Mar 2014 Location: weymouth Posts: 16 ![]() ![]() ![]() |
Hi, thanks for all the advice, i have checked hoses gear select and still the same.
