Home > Technical > Reverse lights stopped working
JamesRoberts
United Kingdom 2005 Range Rover Sport TDV6 SE Cairns Blue
Hi, my reverse lights have stopped working.
It's not the bulbs as they work on other lights.
When I select reverse it shows as R on the dash.
Any ideas?
Thanks
Post #445743 Thu Dec 18 2014 2:58pm
JamesRoberts
Bump
Post #445914 Sat Dec 20 2014 3:16pm
Disco_Mikey
Possibly a blown fuse, or both bulbs have blown Thumbs Up
Post #445921 Sat Dec 20 2014 4:09pm
JamesRoberts
It's definitely not bulbs. Any idea which fuse?
Post #445922 Sat Dec 20 2014 4:14pm
JamesRoberts
Just thinking if it was a fuse surely rear/brake lights wouldn't work either?
James
Post #445925 Sat Dec 20 2014 5:09pm
Paddi
Separately fused. Reverse lights are number five. Top row in passenger compartment fuse box. Access by dropping the lower glove box. You just have to drop it to the normal position then depress the supporting arms to drop it further. 2008 MY Java Black TDV8 HSE
Post #445927 Sat Dec 20 2014 5:30pm
Disco_Mikey
Edit: Wrong diagram.
Post #445931 Sat Dec 20 2014 6:13pm
