Home > Faults & Fixes > Driver Side Headlamp!
Neil,C
England 2005 Range Rover Sport Supercharged Zermatt Silver
After changing the brake sensor cable I noticed afterwards that the Driver side headlamp was not working. I've just bought another bulb,70 quid!!! Hey presto it doesn't work. Could it be linked or does it have a separate fuse? Any help would be appreciated, Thanks.
Post #445217 Sat Dec 13 2014 3:03pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Drivers Side Headlamp
I had that problem, I did a number of elimination tests. I swapped the starter blocks off Bulb connector N/S lamp to O/S. It turned out to be the big electronic block attached to bottom of headlamp,Changed that for about £110 It was fine itisme
Post #445270 Sun Dec 14 2014 9:40am
Disco_Mikey
As above. You have a working headlight on the other side of the car, so it is a case of swapping bits over one by one, until it does start working again Thumbs Up
Post #445277 Sun Dec 14 2014 10:39am
Neil,C
Thanks for the replies, I'll go and give it a go. Thumbs Up
Post #445284 Sun Dec 14 2014 1:50pm
Neil,C
Ouchy!! I changed the starter blocks over and whilst doing this I managed to trap the live wire. This caused a short and knackered the Ballast. Big bill on Christmas Eve Sad I'll be more careful next time.
Post #446673 Mon Dec 29 2014 4:24pm
