![]() | Home > Faults & Fixes > Rear glass tailgate fault |
cubbyno9 Member Since: 22 Oct 2010 Location: Stepps Posts: 149 ![]() ![]() ![]() |
Hi all,
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Hi ShooterNeil,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Part number you need is YUZ500020
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
It is the release handle under number plate shroud,behind rubber cover. The alloy hinge type thing that pushes the micro switch gets corroded and sticks. If you clean this part and give it a good dose of WD40 it will be fine. I did mine 2 years ago and it is still fine. Otther option is a new complete switch about £25/£30 and easy t do. itisme |
Hi Mikey and Harry, I am back from offshore this week so will have a go at the good old WD40 first. 2017 Range Rover Sport HSE |
If that doesn't work, I keep a switch in the back of the car |
Hi Mikey I see by your link there is a switch on Ebay for £19.99 Free Pstage From Islelandrover Doncaster. I have used them before when my LED Rearlight Cluster was stolen. They are very cheap £178 for the light,was delivered next day |
Thanks Mikey, cool I will catch up with you when I get back, cheers 2017 Range Rover Sport HSE |
