Home > General (L494) > Issues connecting phone via bluetooth for music |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
I have had this problem with both my RRS and different phones - phones connect no problem but audio streaming is a nightmare
Fri Nov 28 2014 9:58am |
Nigel Tracey Member Since: 25 May 2014 Location: Lausanne Posts: 44 |
You may be onto something there. Thinking about it now I have recently connected an old iPod with hardwire so maybe this has screwed it up |
Fri Nov 28 2014 10:03am |
SDV6RRS Member Since: 08 May 2013 Location: Hampshire Posts: 52 |
I'm pretty sure it is documented that you can't have Bluetooth music if you have an iPod (or iPhone) connected via USB 2014 MY RRS HSE Dynamic
Fri Nov 28 2014 6:21pm |
This would suggest that I haven't read the manual, honestly some people
Fri Nov 28 2014 6:22pm |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 |
Definitely can't have Bluetooth audio while using USB connection. You can access your song list on the phone or iPod but it's not very intuitive. RRS P460e
Fri Nov 28 2014 9:26pm |
It's a shame because it means you need to disconnect the iPod each time you want to use a bluetooth feed. |
Fri Nov 28 2014 9:31pm |
Sorry I only use my iPhone in the car so didn't realize that if you plugged another device into the USB that you lost the Bluetooth audio off the phone. I'll have to try it. RRS P460e
Fri Nov 28 2014 9:34pm |
I would prefer to use my phone only but find the limited control through the RR interface too limiting hence I switched to a spare iPod which then gives a full control |
Fri Nov 28 2014 9:36pm |
OK can confirm that it works as suggested above. Disconnected the iPod and the phone via bluetooth appears active again. |
Sat Nov 29 2014 9:14pm |
Mine reconnected today too without ipod plugged in but as said above bit disappointed that phone music is so basic - prefer the full functionality of ipod Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Nov 29 2014 9:17pm |
