Home > Technical > Sc crank pulley came off
bennyrrssc
Scotland 2005 Range Rover Sport Supercharged Zambezi Silver
So I was driving home from work today and all of a sudden I get a Xmas tree light up on the dash. Suspension fault, battery light and the steering goes heavy. I limped to the garage (only 2 mins from where it happened) and had a look to find the crank pulley had come loose and rattled off. The garage say they will have a look for me and there is no visible damage elsewhere with the pulley coming off. Is it just a case of bolting back on and locktighting the bolt and setting the belts again or is it a bit more serious? Crying or Very sad
Post #443849 Thu Nov 27 2014 9:06pm
ian-r
You may get away with it, depends whether it has damaged the crank or threads inside the crank where the bolt goes when it came off. Has the bolt snapped or just worked lose? Presume it must have had the pulley off at some point and not been tightened up right.
I once had one like this on a Shogun, he wasn't as lucky as you though as the pulled launched itself through the radiators!
Post #444182 Tue Dec 02 2014 7:45pm
bennyrrssc
Well just been to the garage to see how it's getting on. They had it all sorted a new tapered washer on the retaining nut. It was out for a test drive and on the way back it spat the pulley off again. Big Cry
Can anyone confirm the torque value for it. I had 270 nm 200 lbs. ft
Any reason why it would want to back off the retaining nut and then the pulley?
Post #444440 Fri Dec 05 2014 3:40pm
ian-r
Have they used thread lock? Inspected the threads in the crank for damage / made sure the end of the crank isnt damaged / gone oval?
Post #444441 Fri Dec 05 2014 3:45pm
ian-r
Not sure if its the way the photo is taken, but to me it looks like some of the threads have pulled out of the inside, and the end of the crank doesn't look so good.
By the way, if it has pulled the threads out or damaged the I have known engineering companies come out and drill / helicoil in situ with excellent results.
Post #444442 Fri Dec 05 2014 3:47pm
