![]() | Home > Technical > Sound System |
ddazzler Member Since: 29 Sep 2006 Location: Good ol oz Posts: 19 ![]() ![]() |
Had been looking into the Eclipse unit at the weekend after seeing it advertised in Sydney Motor Show newspaper insert. If you are interested I found a forum saying http://www.glprosound.com.au/ in Dandenong were $3500 fitted.
chex Member Since: 06 Mar 2006 Location: UK Posts: 210 ![]() |
$3500AU = $2700USD |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
yep, that's it.....not like back in the good old days when the AUD was actually 1.10 against the greenback ![]() Other issue with buying any Sat Nav products outside your country......you get pinged big time for the country map software. For the Navman, just the map card and disk was about $400!! Kind of kills of any duty free benefit you may have got on a $800 unit ![]() ![]() |
jbrac25 Member Since: 09 Apr 2006 Location: Alta Loma CA Posts: 12 ![]() ![]() |
Im sure its against copyright laws but has anyone tried to burn a backup of their nav cd and put it in their dvd player? I think it would have to be on a dual layer disc. |
Driller Member Since: 18 Aug 2006 Location: Perth Posts: 80 ![]() ![]() ![]() |
There is a wonderful program called Alcohol 120%, i'm sure you could do something with this...... |
