Home > General > Rear Pad Lifespan?
TheDB
TheDB wrote:
55k miles on the same pads front and rear.
Ha Ha - that will teach me for bragging. Big Cry
Just had a rear caliper fail, binding pad to disk. Quite a grinding noise.
So time for new Brembo discs and pads on each corner plus a pair of recon rear calipers
Thanks to Steve at Advanced Factors for fast delivery and great pricing.
Also thanks to geoff. for squeezing me into his hectic schedule to fit the parts.
So the old discs and pads actually lasted 61K miles over 5 years years or so
Not bad.
Post #444209 Wed Dec 03 2014 12:13am
wemeadows
United States 2013 Range Rover Sport 4.4 V8 HSE Lux Fuji White
9,000 miles and still the original set of brake pads. Last visit to the dealer showed little wear, but the rears are lower than the front 2013 RRS HSE Lux, Fuji White w/Silver Pkg, 5.0 V8
Gone, but not forgotten: 1995 RR County Classic SWB, Arctic White
Post #444284 Wed Dec 03 2014 8:09pm
drdelrrs
Not sure if the RR & RRS are the same but on many cars the stability control can use the rear brakes when it feels it necessary - a Jag XF I had was heavy on rear pads (12,000miles) in comparison to the BMW 5 series it replaced which had covered 30,000 before being sold with the original pads.
If you're in the habit of driving your RRS in a spirited way this could explain why the rear pad life is less than the fronts which is contrary to what we'd normally expected.
Post #444383 Thu Dec 04 2014 7:17pm
